I'm looking for the smallest wheel spacer possible (3mm?) so my front brake calipers will clear my stock six-spoke 16s. I have the BAT kit, and every so often I get minor rubbing between the passenger-side caliper and wheel. I've seen the ones FS sells, 5mm on both sides would be a bit overkill for my application and I don't want to have to put them on all four corners just to keep everything looking the same if I can help it (assuming +3mm offset on the front wouldn't be noticeable without spacers on the back.)
e- Are the universal e-bay variety spacers OK or should I steer clear of them?
TIA
TIA
