1 - 4 of 4 Posts
I was gonna use the svt lower but I think a one piece will be really nice.
Sent from my SM-G900V using Tapatalk
Nice work! I'm looking forward to seeing how this works out!
Sent from my iPhone using Tapatalk
Thanks, I think if everything goes well I may end up making 3 of these. The part with the velocity stacks is already set to use the svt lower so I think I'll keep it and make 2 one piece intakes. The runners are bigger than the ports though so I have to find something else or find a way to reduce it. It works good with the svt lower as you can see though.
Discussion Starter #4
Found my first issue, the stock svt lower is notched to clear the head. Had to do the same with the aluminum flange. The aluminum flange also has 2 extra bolt holes so that should help
1 - 4 of 4 Posts
