1 - 5 of 5 Posts
Does anyone know if you can add after market fog/driving lights to the lower grille on a 2003 focus SE? when I look at my car, it's all one piece, but I've noticed that some cars have a separate lights and a center grille
You can source the assembly from a junkyard. I believe some '03 cars were prewired for foglights. Will need lower grill, fog lights, and switch minimally if your car was wired.
OP, bringler is talking about stock lower grills that come with fogs, not aftermarket. Just check to see if you have a wire and connector dangling below the headlights with no where to go. Then you can do as he said easily. IIRC, you won't need a new relay, just the light switch and grill from a car with fogs.
Discussion Starter #4
Thanks, I'll have to check it out! :)
Wish list,
Spec-D Tuning LHP-FOC00JM-8-TM Ford Focus Audi R8 Style Led Black Projector Head Lights Pair
Spyder Auto Ford Focus Black Altezza Tail Light
2000-2004 FORD FOCUS LOWER GRILLE (with O.E Fog Lamps) (Aluminum Silver)
00-07 Focus 4 Door 12 LED 3rd Brake Trunk Light Chrome Housing Smoke
I also want to replace all my stock bulbs with LED
1 - 5 of 5 Posts
