1 - 7 of 7 Posts
Have an 2004 2.0l dohc with the D.O.D. So far I’ve checked every fuse with a voltmeter to verify continuity. All check out good. Have switched relays around to no avail. I’ve identified, cleaned and tighten 5 grounds on both inner fender areas as well as the top ground to the head. I’ve checked the ground wire that’s for the ecu. Nothing worked. So I bought a ecu with new programmed keys and everything...installed and still have the DOD....no crank, no fuel pump, nothing. Lights work as well as other electrical components. Any suggestions?????? I’ve read through countless threads and multiple forums, I’ve follow tried everything I’ve read so far and still nothing. Any help would be greatly appreciated, and if anyone knows of any other ground connections that I can check, please let me know!
Thank you!!
1 - 7 of 7 Posts
