41 - 51 of 51 Posts
Don't Call Me Gaga!
Maddogmil said:
HOW BOUT THE INFO ON CAUSES OF P2196 PLEASE! rumor has it that o2 dont fail rich.
I'd recommend starting a fresh thread, this is informational only.
In your case, I'd examine wiring to/from the O2 sensor to verify it isn't in some way damaged. Once that is verified good, you have to assume that either the sensor is non-functional, or it is actually reading rich due to a tuning or mixture problem elsewhere.
I'd recommend working with somebody experienced to examine the car.
Wow this thread is helpful haha, but when I set it up to the computer it came back with PO602 an 605. Any suggestions to fix this? The check engine light was on, but after I took out the performance chip it was off again but I drove probably another 100 miles and its now back on. My car's power seems really low also and kinda stutters or hesitates during high rpm's.
Thx for the help guys
what about p2195? i got this along with p0171.
"Shut Up man, get on my horse"
thanks!
9868????
DoubleStuf™
I just got a 2195 also. Called the dealership and they said:
O2 Sensor 11 indicates lean.
Sensor not switching properly. Should be switching rich / lean / rich / lean but instead indicating lean. Tech told me the most likely cause was a vacuum leak.
41 - 51 of 51 Posts
