1 - 5 of 5 Posts
My Son's Upper Intake Manifold blew apart during a massive engine backfire during the 2018-19 Winter Polar Vortex. We found the upper intake manifold, but now also need the lower intake, as the lower mounting bracket is damaged as well. Does anyone have one for sale or know where to locate. Also, I need direction on its Fuel Rail Removal, as I'm an older carburetor type car guy. We appreciate any help in getting his SVT back on the Road again!
The one time mine backfired like that it was because I had lost teeth on the timing belt, so the engine was out of time. I would verify the timing belt condition unless you are positive it is unrelated. Otherwise you will be looking at bent valves.
Discussion Starter · #5 ·
Hi - We'll definitely investigate this further. We truly appreciate your words of wisdom and the Fuel Rail Removal Instructions. What / where did you locate the Ford Focus Instruction Manual?
Thanks Again!
1 - 5 of 5 Posts
